Convert value
trung05101
Convert value
Post by trung05101 »
Hi all!
I use matlab read data from Active Two by TCP.
I use command: data = fread(t, 2, 'int32') (t is server).
Result data= 1.0e+009 *0.9121. If a change int32 by int16, result
data = -32457. I don't know what result is true and how to check it.
Thanks.
Construct 24-bit data words from groups of 3 successive Bytes, see the LabVIEW code of the client. Check your Matlab client by comparing your results with the values displayed by ActiView, by the simple BDF file reader, and by the LabVIEW client.
trung05101
Thanks1
