Hi all,
Recently my lab has purchased new computers which don't have a parallel port. Therefore, we tried to connect our BioSemi ActiveView 2 system via the SD-MS-TCPUA USB / Parallel 24-Bit Trigger I/O Interface. We can see that the system is properly connected because we can manually send triggers via the Ni-DAQmx software, also, the Presentation software successfully identifies the device. The experiment computer identifies the device as NI-USB-6501 and the monitor computer identifies the connection as RECEIVER-2. The problem is that we are unable to make it work with either e-prime or Opensesame, which are the experiment software we normally use in the lab.
Does anyone here have any experience with e-prime 2\ Opensesame with the specified io? I would really appreciate it if you could point me in the right direction.
Thank you!
Shalva
