BioSemi Users,
What is the maximum resolvable frequency given a sampling rate of X on the BioSemi system with ActiveView2 software? Is it X/2Hz? I believe it is X/4Hz on neuroscan systems, and I was curious about how bioSemi compares.
If we are sampling at 1024Hz, can we resolve up to 512Hz?
thanks in advance!
Brian
sampling rate and bioSemi nyquist
In the ActiveTwo, the-3dB point is at approx 1/5th of the sample rate, also see http://www.biosemi.com/faq/adjust_filter.htm. For a selected sample-rate, the ActiView software displays the cutoff frequency in the right sidebar. Competing systems with a 24-bit ADC show exactly the same low-pass response.
The ActiveTwo system uses DC coupled amplifiers, no high-pass filters are applied. The high dynamic range of the used 24-bit ADCs allowed elimination of all coupling capacitors from the design. So, the above statement is correct: the lowest resolvable frequency is only limited by the duration of the experiment.
