(Un)locking the Pause Button of ActiView using triggers
Toycito
Post by Toycito »
Hello all,
I read in the following link http://www.biosemi.com/faq/trigger_signals.htm that is possible to control the Pause Button of Actiview by means of parallel port. I checked the cfg file that is recommeded, but I don't catch the idea. Has anyone used it?
Thanks in advance
Toycito :roll:
Open the CFG with Notepad, scroll to the bottom:
PauseOff=-1 //-1 is disabled, 0-255 is enabled
PauseOn=-1 //-1 is disabled, 0-255 is enabled
Edit the -1 values to the trigger codes that you want to control the push and release of the pause button.
Do not change anything else in the CFG.
Toycito
Post by Toycito »
Hello Coen,
Thanks again as usual. You always help me a lot!
Cheers :!:
:wink:
