Event Markers on Actiview with Biosemi Active two
Brian37
Post by Brian37 »
I am wondering if it is possible to create event markers on the actiview software, so our lab can see what was going on during that time when the eeg analysis takes place.
You can use the keyboard function keys F1-F8 to set markers on trigger lines 9-16. The triggers lines 9-16 should be normally low to use this feature (connect pins 9-16 to pin 37 at the trigger connector).
