Acquisition software SDK support for ARM platforms
Posted: Thu Sep 14, 2023 2:52 pm
				We are trying to develop a system for processing the EEG signals from the ActiveTwo system in real-time on an FPGA.
We are using the Pynz-Z2 FPGA board with a 32-bit ARM A9 processor. We plan to read data from the USB2 interface using the ARM processor running linux and then stream the EEG signals to our custom logic. Basically we need to interface with the biosemi USB2 receiver from an ARM processor running linux.
The "SDK for making your own acquisition software"https://www.biosemi.com/faq/make_own_ac ... ftware.htm given in the downloads page looks perfect for this. However, it seems the SDK ships with some binary files compiled for the x86 architecture. While compiling using the makefile in the "Linux32" folder, i get the following error:
The "file in wrong format" i believe indicates that the binary file was built for another architecture (probably x86 i guess).
The Makefile is as follows. I had modified the "ARCH" variable from "-m32" to "-mbe32" to compile on ARM
How can we proceed to develop the pipeline for linux on 32-bit ARM? Is the SDK available with ARM support, or is there any way i can get the required object files (bsif_inject_socket_samples.o, bsif_socket_io.o, bsif_libusb.o, bsif_tap_usb_samples.o) compiled for ARM?
Code: Select all
xilinx@ramancam:~/biosemi_usb/RingBufferLibrary-Linux/Linux32$ make
make: Warning: File 'ringbuffer.o' has modification time 838 s in the future
rm -f libRingBuffer.so.0
g++ '-mbe32' -o libRingBuffer.so.0.0.1 -fPIC -lc -shared -pthread -lrt -Wl,-soname,libRingBuffer.so.0 \
	ringbuffer.o bsif_libusb.o bsif_inject_socket_samples.o bsif_socket_io.o bsif_tap_usb_samples.o -L./lib -l usb-1.0
/usr/bin/ld: bsif_libusb.o: relocations in generic ELF (EM: 3)
/usr/bin/ld: bsif_libusb.o: error adding symbols: file in wrong format
collect2: error: ld returned 1 exit status
make: *** [Makefile:17: libRingBuffer.so.0.0.1] Error 1
Code: Select all
ARCH='-mbe32'
ALL: libRingBuffer.so  RingBuffer_SyncTest
ringbuffer_synctest.o: ringbuffer_synctest.cpp
	$(CXX) $(ARCH) -Wall -c -o $@ $^
RingBuffer_SyncTest: ringbuffer_synctest.o
	$(CXX) $(ARCH) -o $@ $^ -L. -lRingBuffer
ringbuffer.o: ringbuffer.cpp
	$(CXX) $(ARCH) -Wall -fPIC -c -o $@ $^
libRingBuffer.so.0.0.1: ringbuffer.o bsif_libusb.o bsif_inject_socket_samples.o \
	$(CXX) $(ARCH) -o $@ -fPIC -lc -shared -pthread -lrt -Wl,-soname,libRingBuffer.so.0 \
		$^ -L./lib -l usb-1.0
# make the linker name and soname pointers
libRingBuffer.so: libRingBuffer.so.0.0.1
	ln -sf $^ libRingBuffer.so
	/sbin/ldconfig -n .
clean:
	rm -f ringbuffer.o
	rm -f ringbuffer_synctest.o
	rm -f libRingBuffer.so.0.0.0
	rm -f RingBuffer_SyncTest
