I am working on a project where we're using Digitze software, which writes files into the ERPSS format. The sampling rate of the data is 500 Hz. Biosemi saves in the BDF file format and it samples at 512 Hz, 1024 Hz, and 2048 Hz. Is there a way to change the sampling rate to 500 Hz? Are there any tools that I can use to resample the Biosemi data to 500 Hz? I was also wondering if there is any software out there that allows you to convert BDF to RAW format?
Thank you.
