One or more output arguments not assigned during call to "read_24bit"
Posted: Fri Nov 15, 2019 12:52 pm
Good afternoon,
I have recently experienced the following error message when trying to import BDF files that could however be viewed with the BDF READING tool.
I have tried to repair it using the REPAIR tool, which has unfortunately led to the same error message.
Could you help me with this and tell me how to solve the problem?
Thanks in advance,
Adélaïde
One or more output arguments not assigned during call to "read_24bit".
Error in read_biosemi_bdf>readLowLevel (line 282)
buf = read_24bit(filename, offset, numwords);
Error in read_biosemi_bdf (line 257)
buf = readLowLevel(filename, offset, epochlength*nchans); % see below in subfunction
Error in ft_read_data (line 408)
dat = read_biosemi_bdf(filename, hdr, begsample, endsample, chanindx);
Error in RLW_import_BDF (line 26)
dat=ft_read_data(filename);
Error in LW_import_BDF (line 86)
[out_datasets(filepos).header out_datasets(filepos).data message_string]=RLW_import_BDF(filename);
Error in letswave_gui>menu_callback (line 387)
[configuration,datasets]=eval(eval_st);
Error while evaluating Menu Callback
Thanks in advance,
Adélaïde
