Ergo port, treshold voltage for trigger
Posted: Thu Jan 26, 2023 6:17 pm
by boris5541
I couldn't find anything about what voltage the Ergoport triggers when configured as trigger. Can I also adjust this value?
Re: Ergo port, treshold voltage for trigger
Posted: Fri Jan 27, 2023 3:40 pm
The one-shot trigger characteristics can be adjusted in the CFG (use ActiTools --> Configurator). Further explanation is found at
https://www.youtube.com/watch?v=_OMoXttIguc&t=560s
Posted: Thu Feb 02, 2023 5:17 pm
by boris5541
Thanks for the information. I have a biosemi with two ergoports and connected two sensors. Sometimes I get a lot of noise (200mv pp) at ergoport 1 but after waiting a few minutes, the noise disapears, while ergoport 2 is working perfectly fine. I used +3v and -2v to power the sensor, and 0v is not connected. Switching the two sensors gives me the same result, aka the problem is not caused by the sensors. I measure between +10 and +200mv.
Oh, and I checked the plug thoroughly and resoldered everything to make sure it's well connected.
Posted: Thu Feb 02, 2023 7:06 pm
Sounds like a missing/floating 0V/Ground. Sensor output should probably be referenced to 0V. Connect the 0V to the sensor Ground/Common. Supply datasheet of sensor.
Posted: Thu Feb 09, 2023 1:17 pm
by boris5541
sensor type:
https://www.omega.com/en-us/pressure-me ... V5(150psi)
Sensor messures between .5 volts and 4.5, measuring 0-2 bar. Supply of the sensor is connected between +3v and -2v. Input of Biosemi is connected via a 2k7 resistor to the sensor and via a 5k6 resistor to +3v. There's two ergo ports in the enclosure. Port 2 works fine, port 1 does not.
Posted: Thu Feb 09, 2023 2:00 pm
Did you connect the inverting inputs of the ERGOs (pins 5 and 7) to 0V/Common (pin 2) ?
Posted: Thu Feb 09, 2023 6:45 pm
by boris5541
No, I didn't. Should I?
Is there any way to view the y axis in absolute voltage in active view?
Posted: Thu Feb 09, 2023 7:21 pm
Yes you should, unconnected inverting inputs could explain the above problems. Inverting inputs to 0V is OK, but in your case is even better to connect the inverting inputs via a 5k6 resistor to +3V, AND via a 3k7 resistor to -2V (better rejection of supply voltage ripple because both inverting and non-inverting inputs reference to the supply rails).
Absolute values can be seen in ActiRead ---> Value (
http://www.biosemi.com/download/ToolsFo ... 02-Win.zip), but not in ActiView.
Posted: Mon Feb 13, 2023 5:21 pm
by boris5541
Thanks, that worked!
Posted: Wed Feb 22, 2023 12:47 pm
by boris5541
Is there any method to adjust the trigger threshold during runtime?
Posted: Wed Feb 22, 2023 6:45 pm
ActiView is open-source. You can change the LabVIEW code to not read the trigger level from the CFG, but from an added adjuster.
