send trigger using Arduino
Posted: Mon Jul 04, 2022 8:24 am
Dear all.
I have a question about sending the arduino trigger, so I'm asking.
I want to leave a trigger on eeg data through arduino when recording eeg using biosemi.
I was the answer that you can connect the digital output of arduino to the usb-reciever (of bio-semi).
Does this mean to connect the "trigger in/out" cable to the arduino?
(Does that mean that the end of the trigger port cable (usb 2.0) should be connected to arduino?)
If possible, please explain in more detail.
The way I think it is now is to install a USB to Serial commuincation module in arduino to generate a trigger and connect it with the "trigger in/out" port of USB-receiver.
Can this method shoot a trigger through arduino during eeg recording?
I look forward to your valuable reply.
Thank you.
Regards,
Hyejin.
Thank you.
Regards,
Hyejin.
