USB Receiver USB-1-Mk2 vs USB3
Posted: Fri Feb 20, 2015 6:50 pm
				Hi
I have two USB receivers adapted to be used with the Jazz-Novo. One of them is the USB receiver USB-1-Mk2 while the other is the USB3 version.
In order to send the triggers to the USB box through the parallel port, in our lab we use a special homemade box that is, basically, a parallel-to-usb converter. Despite everything works perfectly with the USB-1-Mk2, when I use the other USB receiver it doesn't recognize the USB.
Do you know if there are differences between USB-1-Mk2 and USB3 receivers? For example, is the firmware different? Where can I find a datasheet or a manual of the two receivers?
Davide
Davide
