Hi
When using the API for collecting data I can't get any data from the Jazz Eyetracker. Do I need to set a flag to enable the Eyetracker?
These are the numbers I get when I run it. The values for the data is not correct. I just want to see that the channels are open. I read in an other thread that ringbuffer[266] to ringbuffer[281] are the sensors. And when I counted the remaining channels after the Auxiliary sensors I thought that the remaining channels was the eye tracker but they returned 0 except 279. Then I thought that I might need to activate the eyetracker like I have to do in the ActiView. Can I activate it?
                                          Ringbuffer nr:
A4 Value: -2125856512       Ringbuff:    6
A7 Value: -2125756160     Ringbuff:      9
A8 Value: -2125872128      Ringbuff:     10
A12 Value: -2125841152     Ringbuff:    14
A17 Value: -2125800192     Ringbuff:    19
A19 Value: -2126320128     Ringbuff:     21
A24 Value: -2125657856    Ringbuff:      26
A27 Value: -2125401088      Ringbuff:    29
EX1 Value: -2125745920    Ringbuff:      258
EX2 Value: -2125959680    Ringbuff:      259
EX3 Value: -2125672448    Ringbuff:      260
EX4 Value: -2125697792    Ringbuff:      261
GSR Value: 825211648       Ringbuff:      266
EyeX Value: 0                Ringbuff:        273
EyeY Value: 0                Ringbuff:        274
GyrX Value: 0                Ringbuff:        275
GyrY Value: 0                Ringbuff:        276
AccX Value: 0               Ringbuff:         277
AccY Value: 0               Ringbuff:         278
OxyL Value: 478593024   Ringbuff:         279
OxyR Value: 0                Ringbuff:        280
Mic Value: 0                  Ringbuff:        281
						Can I enable the eyetracker in the API?
				happilylazy
Re: Can I enable the eyetracker in the API?
I am using fieldtrip application from  donders institute to acquire data, but I also have no data in je JAZZ eyetracker channels, while the other channels are fine.
Is there an enable bit flag somewhere to enable the online acquisition of the JAZZ eyetracker data through the API?
