Is there a way to connect an ePrime serial response box directly to BioSemi?
SRBOX
Re: SRBOX
I want to buy a Response Switch and there are two options: with or without Ergo input. In the Operating Guidelines book, it is stipulated that the response switch can be directly connected to the AUX connection. Why should I need an Ergo connector? What is the function of such a connector?
Also, does the use of the response switch allow to record trigger within the BDF file?
Thank you in advance.
Regards.
Gérard.
Regards.
Gérard.
Re: SRBOX
You need the ERGO connector because it includes the electronic circuitry to process the switch signals.
The switch signals can be stored as triggers 9 and 10 in the BDF file.
Re: SRBOX
> Best regards, Coen (BioSemi)
Is it possible to buy just the electronic part that processes the switch signals?
Re: SRBOX
I have a response switch that I bought on December with an ergo connection. I used it for the two last weeks with no problems --> at each response of my subjects (i.e., in a reaction time paradigm), triggers were sent on the trigger channels 9 and 10. Since today, after one or two minutes on the RT task, the trigger channel 10 remains "on" and it impedes me to record the other events (visual) --> only one event can be recorded at a time. I've been therefore obliged to stop my experiments. Have you ever met this kind of problem? If so, what is the solution? Can I select the trigger channel on which I want the trigger to appear (only the trigger channel 9 for example) and deactivate the trigger channel 10?
Regards.
Gérard.
Regards.
Gérard.
Re: SRBOX
Yes, trigger 9 is still appearing during the task in the ActiView window but I can't find it in my BDF file since the trigger 10 is 'on' all the time and only one trigger can be recorded at a moment. I'll send you our system tomorrow.
Best regards.
Gérard.
Best regards.
Gérard.
Re: SRBOX
Trigger lines 9 and 10 are separate bits in the trigger channel. Even if trigger 10 is High all the time, switching of trigger 9 should always be retrievable from the BDF file (check with BDF reader from http://www.biosemi.com/download/BDFReader.zip)
