TCP/IP server & RingBuffer
Toycito
Post by Toycito »
Hi all,
I'm working on an online system and I've been using the TCP/IP server in order to collect the eeg signals. As far as I understand, the Actiview server sends the data point to a ringbuffer and when I connect my TCP/IP client, the data collection is from here.
If this is correct, what happens when I close the TCP/IP connection and after a while I re-connect my TCP/IP client ?. Is the ringbuffer reset? or what happens with the data that I didn't collect? Does the old data remain there?
Thanks in advance
Toycito :shock:
Data from the AD-box is stored in a ringbuffer. ActiView reads the ringbuffer, display the data on screen, writes the data to BDF file, and streams the data via TCP/IP to a client. When the TCP/IP connection is closed and opened again, the data processed by ActiView during close down of the TCP/IP connection is not available anymore for the TCP/IP client (but meanwhile saving to BDF file may have continued). So long as the TCP/IP connection is operational, no data can be lost without an error message (TCP/IP is a handshaked protocol, ActiView ensures that no data points are deleted).
Toycito
Post by Toycito »
Thanks for your reply. It was really helpful!
:wink:
