EDFbrowser 1.46 is available:
http://www.teuniz.net/edfbrowser/
Changes since version 1.42:
 version 1.46      April 13, 2012
 - Solved a bug that caused a crash when the "Abort" button was clicked
   when opening a BDF-file.
 - Solved some small bugs and made some enhancements.
 - Updated Qt to 4.8.1.
 version 1.45      March 31, 2012
 - Added the possibility to disable scanning for annotations or triggers
   when opening a file, depending of the filesize.
   This can be usefull when working with big files that take
   a lot of time to read-in annotations, events or triggers.
   (Due to the nature of the EDF-format, the annotations-channel(s)
   needs to be read from the beginning till the end of the file.)
   In the "Settings -> other" dialog you can adjust the filesize
   which above EDFbrowser will not scan the file for annotations.
   (between 100 MB and 10 GB)
 - extended the capabilities of the header-editor. Now it can also fix
   files that have a wrong number of datarecords written in the header
   or when the file does not end at the boundary of a datarecord.
   See the manual for the details.
 - Improved the ECG heartrate detection algorithm.
 - Fixed some bugs related to signals with inversed polarity
   (i.e. when physical maximum is lower than physical minimum).
 version 1.44      March 4, 2012
 - Fixed a bug that caused the "print to PDF / Postscript / Image" to fail
   when non-ascii characters where present in the new filename.
 - Fixed a bug that caused "printing to image" drawing the signals too thick
   and wrong rulers.
 - Fixed a bug in the ECG heartrate detection algorithm that could cause wrong
   measurements with high heartrates (more than 120 bpm).
 - Added Mousewheel zoom-in/out by pressing the Ctrl-key.
 version 1.43      Februari 17, 2012
 - Fixed multiple bugs related to annotationmarkers and EDFplus feature to use subsecondprecision in the starttime
   of the file. (Only affects files that uses the subsecond starttime offset EDF+ feature.)
