Send triggers from DATAPixx3 / TRACKPixx3 system to BioSemi system
DrCri
Post by DrCri »
Hi all,
I am setting up a PsychoPy task (Windows 10 / Python) collecting simultaneously eye movement and EEG data.
I have configured my triggers and have managed to send them from my task to the eyetracker.
The next step is to send my triggers from DATAPixx3 to the EEG Biosemi system at the same time but I am not sure what is the best way to do this.
I would like to know if anyone has experience sending triggers from DATAPixx3 to BioSemi system, any suggestion is truly welcome.
C
Re: Send triggers from DATAPixx3 / TRACKPixx3 system to BioSemi system
Make a parallel cable to connect the 25-pole trigger output connector of the DATAPixx3 to the 37-pole trigger input on the BioSemi USB-receiver. The BioSemi "Presentation" cable will probably work (compare the pinout of the DATAPixx3 with https://www.biosemi.com/faq/presentation.htm )
DrCri
Post by DrCri »
Thanks for your reply Coen.
C
