How (if possible) do I use an alternative to Presentation/EPrime for stim presentation, such as Matlab (w/ psychophysics toolbox)? I assume that I just need to figure out how to pass event codes to the Biosemi inputs? Also, while I can use a PC if necessary, is there any way to do this on a Mac, which has no parallel port?
thanks,
-Steve
using matlab + psychophysics toolbox for presentation
matlab -> biosemi
Haven't gotten any responses yet, but will post the answer here if I ever get one. Given Matlab's popularity, someone must've solved this.
-Steve
-Steve
Bits++
For Mac / MATLAB / Psychophysics Toolbox users. See Bits++ by Cambridge Research at http://www.crsltd.com/catalog/bits++/. This is a solution for precise video and digital IO from a Mac or a PC.
Lloyd Smith
lsmith@cortechsolutions.com
here's a description on how to set up triggers which is used within psychtoolbox:
http://psychtoolbox.org/wikka.php?wakka=FaqTTLTrigger
MATLAB API for recording direct from ActiveTwo
If you are interested in an open source MATLAB API for ActiveTwo, see this topic viewtopic.php?p=2049#2049. Thanks.
Lloyd Smith
