Dear all, I wrote a C++ program to receive data from ActiView software in two seconds. I set a timer to ensure the time period of my program is precisely two seconds.The sampling rate was 2048 Hz, and TCP samples/channel was 16. So it means that the data sending frequency was 128Hz. However, the number of data were different each time. Hence, I want to ensure whether the data sending frequency is precisely 128Hz or fluctuate within a certain range.
Thanks in advance for your help,
Ming
Sending Frequency of data from TCP/IP
Re: Sending Frequency of data from TCP/IP
The data is buffered (in the ringbuffer and in ActiView and in the TCP/IP protocol) so the sending rate over TCP/IP fluctuates.
Collect 4096 samples in your receive program, and you have exact 2 seconds of data.
Thanks for your help. It solves my problem .
I have another question. When I select a sampling rate, 'TCP samples/channel' in Actiview interface 'TCP server' is generated automaticly. For example, if I set the sampling rate as 2048 Hz, the value in 'TCP samples/channel' is 16. How can I change this value?
Thanks in advance for your help.
Regards,
Ming
The TCP_samples/channel is generated in ActiView and linked to the packet size that is used to read the ringbuffer and the minimum step size for scrolling the data on screen. You can change only the value by editing the (open-source) LabVIEW code of ActiView (LabVIEW programming environment required).
I open the ‘Active707-Lores’ using LabVIEW and I find the wiring terminal related to the ‘TCP samples/channel’, but I don't know how to modify the value. So do you know how to modify it?
Regards,
Ming
Regards,
Ming
I find the wiring terminal of ‘TCP sample/channel’. It’s a display unit. I change it to an input unit and set a value. Then I run the ActiView and receiveCoen wrote: ↑Mon Oct 22, 2018 11:44 amThe TCP_samples/channel is generated in ActiView and linked to the packet size that is used to read the ringbuffer and the minimum step size for scrolling the data on screen. You can change only the value by editing the (open-source) LabVIEW code of ActiView (LabVIEW programming environment required).
the data. The data seems to be no problem, but I am not sure whether my approach is feasible.
Regards,
Ming
Your approach will work, providing that the value generated by ActiView divided by the value you select manually is an integer. For example: if ActiView generates a value of 16 samples/chan, the you can manually set 1, 2, 4 or 8 samples/chan.
