ecg
Posted: Wed Jan 30, 2019 5:39 pm
by rohika
I usually use BIOSEMI system, but in my next experiment, I want to use only ECG.
However, when I use EXG without any brain channel, ECG doesn't work.
If I use CMS and DRL, ECG works well, but participants need a cap.
Could you please let me know whether ECG without CMS/DRL is available or not?
If yes, please let me know how to do it.
Thanks in advance.
Re: ecg
Posted: Thu Jan 31, 2019 2:43 pm
CMS/DRL is required for any electrode measurement. When not using the headcap, use a seperate (flat) CMS/DRL connected to the front-panel of the AD-box.
Re: ecg
Posted: Fri Feb 01, 2019 10:11 am
by rohika
Thanks.
Could you please let me know which special cable I should buy?
Sincerely yours,
rohika
Re: ecg
Posted: Fri Feb 01, 2019 12:35 pm
Order "CMS/DRL Flat Set" (EUR 100 excl. shipping). First check that your AD-box has a CMS/DRL connection on the front-panel (there should be a CMS/DRL label above the most left DIN connector). If not, order "CMS/DRL Flat Set SCSI".
Re: ecg
Posted: Fri Feb 01, 2019 2:40 pm
by rohika
Thanks.
Our AD-box has a CMS/DRL connection.
Is this "CMS/DRL Flat Set" correct? (order code: CMSDRL FLAT)
https://www.biosemi.com/flat_electrode.htm
Sincerely yours,
Rohika
Re: ecg
Posted: Fri Feb 01, 2019 3:57 pm
by Robbie303
CMSDRL FLAT is the ordercode.
There is no image of the CMSDRL FLAT on the website.
For EEG we advise Signa gel.
For all ECG/EMG/EOG measurements we advise Elefix.
The skin on the chest, arms and legs is more difficult to penetrate and make contact with.
That is why for ECG/EMG/EOG, a stronger gel is needed: Elefix.
So, when using TP FLAT electrodes or CMSDRL FLAT electrodes, you need Elefix.
Re: ecg
Posted: Mon Feb 04, 2019 2:23 pm
by rohika
Thanks, I will try it.
