Recording EOG's
edow
Recording EOG's
Post by edow » Tue Jan 20, 2009 8:11 am
I was wondering if anyone knows how to just record the EOG channels without having to record all the other cap electrodes?
Post by Coen » Tue Jan 20, 2009 4:42 pm
Use the "Free Choice" channels selection to display just the EOG channels in the monopolar display, and select "Monopolar Displayed Channels" as save subset in the file save dialog.
edow
Post by edow » Tue Jan 20, 2009 11:05 pm
This is going to significantly reduce disk space. Your help is much appreciated, thanks alot!
Liz
cemiller
Re: Recording EOG's
Post by cemiller » Mon Jun 23, 2014 11:40 am
Is there a way to only record EOGs, without using scalp electrodes? From what I understand DRL and CMS need to be used regardless?
I am hoping to use the system to look only at eye movements, and wanted to avoid having to use the cap if possible.
Re: Recording EOG's
Post by Coen » Mon Jun 23, 2014 3:25 pm
Use a flat-type CMS/DRL conencted to the frort-panel of the AD-box.
cemiller
Re: Recording EOG's
Post by cemiller » Mon Jun 23, 2014 4:23 pm
Excellent, I forgot that you make those flat as well. Is there an optimal place for positioning the CMS/DRL electrodes? Does it matter where they go on the head/face?
Sorry about all the questions, and thanks for your help.
Best wishes
Re: Recording EOG's
Post by Coen » Wed Jun 25, 2014 10:38 am
The CMS should be approx. in the center of the measuring electrodes, for example on the nose or the forehead.
The DRL can be anywhere on the body. In theory, a location at some distance of the measuring sites is optimal. In practice, a location not too far from the CMS often results in lower interference levels (I don't have a good explanation). Some trial and error to archive the best location for minimal interference levels (in the unreferenced display) may be useful.
