				EEGlab
				Posted: Fri Dec 19, 2008 9:28 am
				by gagan
i have downloaded EEGlab, and the problem is that
1.
i have to give its path every time i want to use it, in the comand window.
does it go like this??
2. it give an error:
Quote:
eeglab: adding "EEG toolbox not installed, plugin disabled" plugin (see >> help eegplugin_eeg_toolbox)
eeg
please tell how should i fix it?
gagan
				Hello;
				Posted: Wed Jan 14, 2009 1:21 pm
				by Nurhi
				if you put the eeglab into your working file then you will not need to add the path every time you start.
The second problem may be because your data and eeglab are not in the same directory..
Regards.
				EEG DATA
				Posted: Tue Mar 24, 2009 7:09 pm
				by gagan
Can you advice me on this:
1.
how to convert and EEG file to a text file?
2. how to send eeg text file to AVR microcontroller through serial communication
Thanks in Advance.
gagan
				EEG
				Posted: Wed Mar 25, 2009 5:17 am
				by gagan
				hi,
everytime i launch eeglab in the matlab workspace then this comes
[u]eeglab: adding "EEG toolbox not installed, plugin disabled" plugin (see >> help eegplugin_eeg_toolbox)[/u]
when i try help (>> help eegplugin_eeg_toolbox) then following appears
[quote]eegplugin_eeg_toolbox() - EEGLAB plugin for plotting ERPs using the
EEG toolbox
Usage:
>> eegplugin_eeg_toolbox(fig, trystrs, catchstrs);
Inputs:
fig - [integer] EEGLAB figure
trystrs - [struct] "try" strings for menu callbacks.
catchstrs - [struct] "catch" strings for menu callbacks.
[/quote]
[quote] Author: Arnaud Delorme, SCC, INC, UCS[/quote]D
but still toolbox doesn't comes. how to enable toolbox plugin?
Regards
Gagan
