Noob using Labview_DLL
happilylazy
Post by happilylazy » Tue Jun 22, 2010 9:05 am
Please if you can help me with this.
I just patched Biosemi to my laptop, installed drivers and downloaded ActiView604-Light, but there is only [b]Labview_dll.dll[/b] withouth header .h or library .lib
So I have written dynamic dll loading, please tell me if I'm doing something wrong here.
[code]#include <stdio>
#include <stdlib>
#include <time>
#include <windows>
#include <conio>
#include <string>
// DLL function signature
typedef HANDLE (*OPEN_DRIVER_ASYNC)(void);
int main (void) {
HANDLE usbHandle;
OPEN_DRIVER_ASYNC opendriver;
HINSTANCE hinstLib = LoadLibrary(TEXT("Labview_dll.dll"));
if (hinstLib == NULL) {
printf("ERROR: unable to load DLL\n");
return 1;
// Get function pointer
opendriver = (OPEN_DRIVER_ASYNC)GetProcAddress(hinstLib, "OPEN_DRIVER_ASYNC");
if (opendriver == NULL) {
printf("ERROR: unable to find DLL function\n");
FreeLibrary(hinstLib);
return 1;
// Call function.
usbHandle = opendriver();
// Unload DLL file
// Display result
printf("The End.\n");
return 0;
[/code]
pmac
Post by pmac » Tue Jun 22, 2010 12:22 pm
There are labview_dll.h and labview_dll.lib files in the driver download package.
If you link with the .dll file you don't need to use the LoadLibrary and
GetProcAddress calls.
Otherwise everything looks OK.
Paul
happilylazy
Post by happilylazy » Tue Jun 22, 2010 2:59 pm
lol, I haven't seen this there. Damn, I'll try this instead since this way I have definitions of the functions.
happilylazy
Post by happilylazy » Tue Jun 22, 2010 3:35 pm
OK, I found header, lib and dll, wrote this simple example, but am I forgetting something here o_O
It doesn't want to compile and whines about:
error LNK2019: unresolved external symbol __imp__OPEN_DRIVER_ASYNC referenced in function _main
fatal error LNK1120: 1 unresolved externals
[code]
#include <stdio>
#include <stdlib>
#include <time>
#include <windows>
#include <conio>
#include <string>
#include "labview_dll.h"
__declspec(dllimport) HANDLE OPEN_DRIVER_ASYNC(void);
int main (void) {
HANDLE usbHandle;
usbHandle = OPEN_DRIVER_ASYNC();
return 0;
[/code]
pmac
Post by pmac » Tue Jun 22, 2010 3:57 pm
Happ,
It looks like the linker doesn't have the labview_dll.dll file.
Do you include it explicitly as a library to be searched?
Paul
happilylazy
Post by happilylazy » Wed Jun 23, 2010 12:10 pm
[quote="pmac"]Happ,
Paul[/quote]
I have been at this for a while now and I keep getting the same error message over and over again, does anybody know how to do this in Visual Studio 2008?
pmac
Post by pmac » Wed Jun 23, 2010 12:53 pm
Happ,
I don't often use Visual Studio.
Have you tried something like this:
http://www.learncpp.com/cpp-tutorial/a2 ... 5-express/
Paul
happilylazy
Post by happilylazy » Thu Jun 24, 2010 8:43 am
OK, so let's start from the scratch.
I have dynamic library labview_dll (.h, .lib, .dll), how do I write the first example program with it in C or C++.
Can you please help me with this, small example or tutorial.
pmac
Post by pmac » Thu Jun 24, 2010 2:26 pm
Hi Happ,
I downloaded Visual C++ 2008 and created a new project.
I added your above code as source file "main.cpp".
In Project->Properties->Configuration Properties->C/C++->General, item "Additional Include Directories"
I added: c:\...\developers kit\c-code (... is whatever is needed on your system to point to the downloaded labview_dll.h file).
In Project->Properties->Configuration Properties->Linker->General, item "Additional Library Directories"
I added: c:\...\developers kit\c-code (... is as above but for the labview_dll.lib file).
I put a copy of Labview_DLL.dll in the same directory as the main.cpp file created above.
I added a ".h" to each of the standard include lines in main.cpp so for instance,
#include <stdio> becomes #include <stdio>
Now your program compiles and runs.
You can harvest code from labview_dll_synctest.cpp to make your acquisition stream data into the ring buffer.
Paul
pmac
Post by pmac » Thu Jun 24, 2010 2:29 pm
Correction:
Paul
pmac
Post by pmac » Thu Jun 24, 2010 2:31 pm
Correction 2:
For some unknown reason the ".h" is being removed in my previous posts!!!
Paul
pmac
Post by pmac » Thu Jun 24, 2010 6:36 pm
Oh, I think I had to do one more thing,
Add Labview_DLL.lib to the project's Source Files as an Existing Item.
Paul
happilylazy
Post by happilylazy » Mon Jun 28, 2010 12:54 pm
Thank you for the help.
Yeah, the ".h" part gets cut of constantly, but I got it.
The thing is, I tried all of the steps stated in your last post but i still couldn't compile. So I asked my very good programming friend and he couldn't do it too, like ".lib" doesn't have all the function definitions.
Can you please "zip" the MS Visual Project, the last one discussed that worked and RapidShare it or somehow else give it to me please.
Damn this frustrates me.
pmac
Post by pmac » Mon Jun 28, 2010 2:04 pm
Happ,
I just did it all again as a new project and it worked!
Did you do this additional step that I posted somewhat later on Thursday:
"Add Labview_DLL.lib to the project's Source Files as an Existing Item. "
What error message(s) are you getting?
Paul
happilylazy
Post by happilylazy » Tue Jun 29, 2010 10:39 am
OK, I forgot to mention my system is Windows7 64bit, and as such I downloaded the Win7 64bit version of the drivers, and they couldn't compile no matter how much I tried.
Then I downloaded 32bit version and voila, it compiled like a charm.
Has anybody had the same problem? Seams like a problem in the ".lib" file. Should I contact BioSemi guys about this?
Still, I have to test are my drivers now compatible with this dll version, I somehow doubt it referencing to main Murphys Law.
pmac
Post by pmac » Tue Jun 29, 2010 11:41 am
According to the following Microsoft page, the Express edition is 32 bits only:
http://msdn.microsoft.com/en-us/library ... S.90).aspx
You can use 32 bit applications on 64 bit Windows but be careful ...
install the 64 bit driver package from BioSemi to get the correct WinUsb driver installed then for development with Microsoft's Visual Studio Express use the labview_dll.lib and labview_dll.dll from the 32 bit BioSemi package.
Paul
happilylazy
Post by happilylazy » Tue Jun 29, 2010 12:39 pm
Tnx, I did exactly that.
But i have MS Visual Studio 2008 Professional Edition so there should be no problem there.
I successfully ran the program and didn't receive any error.
Now I have to get the GSR data and analyze it to use it in the game. Please can you point me in this direction (post, thread, blog).
pmac
Post by pmac » Tue Jun 29, 2010 1:23 pm
For C, you can lift some code from the test program labview_dll_synctest.cpp in the C-code subdirectory of the BioSemi driver package.
There was this recent discussion:
viewtopic.php?t=452
Or consider something built on:
http://www.biosemi.com/download/ActiView604-Light.zip
Paul
