How to send 16-bit event codes?
Posted: Fri Jan 27, 2017 11:38 pm
I am using the ActiveTwo system and would like to send 16-bit event codes. Is this possible at all?
My event code setup is the following:
Matlab --(USB)--> Cortech SD-MSTCPUA --(parallel/DB37F)--> Biosemi USB Reciver 5.1 --(USB)--> Recording PC (ActiView)
On the output side, I am able to open a 16-bit DAQ channel in Matlab and send out 16-bit binary codes. However on the input side (Actiview) my codes appear to be 8-bit only. Can you help finding a solution?
Francesco
Francesco Marini, Ph.D.
University of Nevada Reno
Dept. of Psychology
Francesco
Dept. of Psychology
