Ergo Response Switch
cmmfong
Post by cmmfong »
I'm exploring to use the ERGO response switch in my experiment. However, I am not sure how I can send the responses of the subjects back to the experimental software I'm using (E-Prime). Any hints would be much appreciated.
CM Fong
Re: Ergo Response Switch
Edit the 4th line of the CFG file to:
RespSwitch=1
You should now see the action of the response switches as triggers 9 and 10 in ActiView. At the same time, the triggers are available as output triggers 1 and 2 (pins 17 and 18) of the triggers port on the USB-receiver.
