CMS and DRL?
Posted: Fri May 23, 2008 12:47 pm
We have been working with ActiveTwo equipment. The last year we had been working with the 32 channels and everything went ok. During this year, we started to work with the 64 channels (A-set and B-set). Some days ago, when we were collecting one subject with the 64 channels suddenly the screen showed in every channel flat lines.
We also noticed that when we pressed the CMS and DRL electrodes the signal became normal again, so we think that the problem could be related with these two electrodes.
What do you think?
However, this is strange because we only collect 15 subjects with this equipment.
Because we want to continue the experiment we change the A-set of the 64 channels (P-32-1020-64ACMS) to the A-set of the 32 channels (P32-1020-32ACMS). Do you think that this could lead to some problems? When we did this change everything became normal.
Thank you!
InĂªs
What do you think?
Thank you!
InĂªs
